2000 Volvo S40 Hard Start Low Idle
Old Aug 31, 2018 | 12:52 PM
Porkers's Avatar
Default 2000 Volvo S40 Hard Start Low Idle
Hi, first time poster. I just recently purchased a 2000 S40 with 108k on it. It had codes P1446 P0037 P0505 P0245 P0031 P0130 and P0445. It would start after 10-15 revolutions and run rough. It would stall if I didn't keep my foot on the gas. My reader said to change the PCV valve. I did that job and nothing changed. I checked for vacuum leaks and I absolutely cannot find any. I tried changing the IAC valve and MAF sensor. Now I have a MAF code. So I put the old one back and I still have that code. So I thought that it had to do with the purge valve because of the P0445 code. So I checked that I found that it wasn't sealing. I replaced that, but no change. So I checked the plug and I'm only getting 3.4V on the power side. So I did my own power setup to see if the low voltage was the problem. I hooked the power side to the battery and the ground side to the wire going to the ECM and the idle evened right out. No problems at all. So I go to clear the codes, shut off the car, clear them, and start it up again. It took a second to catch, but nothing like before. And the check engine light stayed off for maybe 5 seconds and then it started running rough again. I went out to check that my wires were still connected. They were fine. I go and check the codes again, and now it's all the same codes, just except for the P0445 code! But I can disconnect the wires, then reconnect them and it seems to completely smooth out. What am I missing? Any help is appreciated.
Old Aug 31, 2018 | 03:30 PM
Porkers's Avatar
I found that the power going to the IAC is also low, about 2.0V. Is their wiring connected? And if it is, what else is in that circuit? So I can check that too.
Old Sep 1, 2018 | 04:41 PM
Hudini's Avatar
Long cranking is a symptom of a bad fuel pressure regulator.
I have no suggestions with the wiring or voltages.
Old Sep 1, 2018 | 05:16 PM
Porkers's Avatar
I took a fuel pressure regulator out of a V40 that I knew was good in and it changed nothing.
Old Sep 5, 2018 | 09:57 PM
AutoNaut's Avatar
+1 for the fuel pressure regulator.
CasperNJ
May 10, 2014 01:12 PM
evince
May 5, 2013 10:20 PM
AGSchear
Oct 11, 2012 10:25 PM
Mutant
Feb 12, 2012 06:39 PM
r2helms
Mar 29, 2009 01:03 PM
