2001 S40 $4500 Repairs?!
Old Jan 11, 2011 | 10:21 PM
Joran's Avatar
Default 2001 S40 $4500 Repairs?!
I have a 2001 S40 with 105K miles on it. The check engine and service lights were both on so I brought it to the dealer.
The dealer says I need both a cam reset valve/pulley replacement (at $1.9K) and both catalytic converters need to be replaced (at $2.6K).
Am I being ripped off here or is this normal? I'm considering junking the car if I need to spend this much.
Thank you so much for your help.
Old Jan 11, 2011 | 11:34 PM
Mad Matt's Avatar
That sounds out of line expensive! Take your car to an exhaust shop for the CAT. Wait, both CAT's??? I thought there was only 1 CAT, 1 Resonator, 1 Muffler. At least that's what I've had on every one of my 4 Volvos. Get the CAT at an exhaust shop, If the resonator need to be replaced as well, just have the exhaust shop cut it out and replace it with a straight pipe. The cam reset valve is a known issue with the cars, but that still seems WAY too much for the job including a simple pulley. Take you car to a good indie mechanic and get a quote from them to compare it to the dealer quote.
Where are you located, and what dealer is telling you this???
Old Jan 12, 2011 | 05:25 AM
jks2's Avatar
Sounds way out of line. +1 on Mad Matt's suggestion. If it really would cost that much, unless you were planning on driving the car for another 6-8 years it wouldn't be worth spending that much money on it.
Old Jan 12, 2011 | 11:09 AM
Joran's Avatar
Thank you so much for your quick response.
I live in the Washington, D.C. area and I took it into Darcars.
The cam reset valve repair was mostly labor, with the parts costing only $400.
The service technician said that the S40 had two catalytic converters and that they wear at the same rate, so they both needed to be replaced at the same time.
Old Jan 12, 2011 | 11:52 AM
GerBeGurGya's Avatar
Yes there is two CAT but the first is metallic the second is ceramic.Different distances from the main heat source and different materials.How the hell could they both go out at the same time.Also the CAT really shouldnt go bad at that millage at all.Volvo garantie covers them I think for 10 years as part of the emission control I guess they wanna try to sell you one.
Old Jan 12, 2011 | 02:02 PM
Mad Matt's Avatar
Now that you mention that, I remember there is a 10 warranty some of the pollution control components. Might want to look into that. If for some reason it's not, I'd still take you car to a quality exhaust shop for the new CAT's. You'll save a bunch of money.
Old Jan 12, 2011 | 02:55 PM
Joran's Avatar
I'll have to look into the warranty. Any suggestions on how to find a quality exhaust shop? The only ones I know of are Meineke or other muffler shops.
Thanks you everyone for your help!
Old Jan 12, 2011 | 03:34 PM
Mad Matt's Avatar
I know nothing about the DC area so I'd just check around your area for an independent exhaust shop. If not, I'm sure Meineke could do it for you.
mimi1
Apr 13, 2014 04:45 PM
snowwillfall
Mar 30, 2014 10:22 PM
chromecarz00
Nov 6, 2013 05:25 PM
nicolaselias
Nov 19, 2011 10:19 AM
ADB
Sep 4, 2011 04:15 PM
