2001 S40 engine hesitates under max accel
Old May 25, 2007 | 01:33 PM
richsid's Avatar
Default 2001 S40 engine hesitates under max accel
pulled P0130 and P0128 codes. I had replace spak plugs because one of the cyclinders was misfiring. Should I change to Volvo plugs? Could that throw the O2 sensor? Or is it the coils? any damage if I don't change the t-stat and t-sensor (as the AC and heat seems to work fine)?
Old May 25, 2007 | 05:59 PM
mcguij1's Avatar
Default RE: 2001 S40 engine hesitates under max accel
the coils should be ok, what kind of plugs were you using? you should stick with either oems or NGK iridiums IV...
Old May 25, 2007 | 11:54 PM
nandrolone's Avatar
I have a 2001 s40 and use only iridiums or volvo brand. Coils do go bad and had to replace mine at 45,000.
Jabdoney
Jun 6, 2015 05:09 PM
bostongrun
Sep 30, 2011 03:57 PM
bostongrun
Sep 26, 2011 11:04 AM
NFrank89
Aug 26, 2011 07:53 PM
