2002 S40 - Inaccurate Ambient temp (2 or 3 off)
Old Jan 13, 2007 | 01:49 PM
m4gician's Avatar
Default 2002 S40 - Inaccurate Ambient temp (2 or 3 off)
Okay guys,
My 2002 Volvo s40 1.9T has the same 3 gauge design as others, Time, Mileage, and Ambient Outdoor Temperature. The problem I have is with the third one as it seems to be giving me temperatures that are 2 or 3 degrees higher than what is actually true, no matter what the temperature is. I don't have trip computer equipped with my car (i wonder if it's available as an add-on now, at this point in time), so it basically just displays the temperature. Now is the reason it's always 2 or 3 degrees accurate because the sensor is dirty? Or it's getting residual heat from the engine, which always smells like it's burning for some reason, not a strong smell, but strong enough that it comes through the vents...
Anyways, let me know guys,
Thanks In Advanced.
Old Jan 13, 2007 | 01:52 PM
Default RE: 2002 S40 - Inaccurate Ambient temp (2 or 3 off)
Usually it will be off that much due to the engine heat.
Old Jan 13, 2007 | 02:41 PM
m4gician's Avatar
What can I do to adjust for that? Or stop the engine heat?
Old Jan 13, 2007 | 07:43 PM
Nothing can be done that is normal operation.
The sensor readings are average.
Old Jan 15, 2007 | 02:22 AM
jwilliam0414's Avatar
You will get this increased temp reading in most vehicles. (Due to the engine heat like tech said). I have noticed that it does read the correct temperature when traveling at highway speeds, due to the increased airflow in the engine compartment which takes that heat away from the sensor.
volvofan1
Aug 28, 2010 09:48 PM
jamweth
May 21, 2010 10:19 AM
Floaterdave
Jan 26, 2009 10:56 AM
gbf1
Oct 30, 2008 04:59 PM
pbair
Mar 19, 2008 09:12 PM
