2003 S40 Vibrations
Old Jun 3, 2021 | 07:15 PM
Beepeawee2's Avatar
Default 2003 S40 Vibrations
I recently got a 2003 S40. 18 years old, yeah, I know, but one previous owner and only 74,000 Kms on it. Looks almost new and drove great to start, and had a complete vetting before I bought it. I've had it a month. Problem is, it has started to hesitate and shake when accelerating at any speed. It will shake if I rev it in park or neutral, too, so, the car does it when not moving as well. If I accelerate slowly it rarely does it, but a hard acceleration will result in a hesitation, quite strong shaking and then a lunge forward, Shaking stops as soon as I take my foot off the gas, both in motion and revving while idling. I am thinking spark plugs but I wanted to ask here before I crept off to the shop to have it looked at.
Old Jun 3, 2021 | 08:00 PM
Any codes stored?
Could simply be worn out spark plugs - but stage 0 would be a good start.
Old Jun 3, 2021 | 08:11 PM
Beepeawee2's Avatar
what is stage 0?
Old Jun 3, 2021 | 08:17 PM
Beepeawee2's Avatar
I'll have to ask the mechanic about codes. I have no clue. ;-)
Old Jun 3, 2021 | 08:20 PM
Originally Posted by Beepeawee2
what is stage 0?
As new - new plugs, air filter, fluids, oil, clean throttle plate, clean pcv, timing belt if needed, etc.
Old Jun 3, 2021 | 08:51 PM
Beepeawee2's Avatar
Gotcha. Thank you. :-) I'll ask him what he did to it prior to getting it. I know the battery is brand new and it had an oil change right before I got it - (and I'd presume the air filter was done with that). I'll call him or drop by tomorrow and find out the rest.
Much appreciated.
Old Jun 4, 2021 | 03:41 PM
Beepeawee2's Avatar
Problem solved - I took it in and yes, it was the spark plugs - also an ignition coil went belly-up and the oil filler cap (aka the 710 <wink>) was cracked. By the time I got it in to him it felt like it had 4 square tires but it was all put right and it's running like it should.
Thanks for the feedback. It was reassuring and on the money.
Old Jun 8, 2021 | 10:25 AM
richardkonrad's Avatar
Great just shows that very low km on does not mean a car is good , car standing for long time will create issues if not serviced on a time period
Old Jun 8, 2021 | 11:50 AM
another issue common to the Gen1 S40s is cracked connectors on the wiring harness to the coil packs. Not a hard part to replace but its not cheap (as I recall it ran me $150-200 US) but for a car approaching 20 years old, it may be time.
Old Jun 8, 2021 | 01:22 PM
Beepeawee2's Avatar
Thanks for the tip!
VolvoC
May 16, 2018 09:36 AM
KC-S40
Nov 10, 2013 02:53 PM
Gmanuel
Nov 1, 2012 08:55 PM
ricerooster
Oct 17, 2012 07:28 AM
medik
Jan 20, 2005 03:58 AM
