2004.5 s40 upstream O2 sensor problems.
Old Jan 13, 2017 | 01:00 PM
redline55's Avatar
Default 2004.5 s40 upstream O2 sensor problems.
hello,
I have had an engine light on for while in my 2004.5 s40 2.4. It was for low voltage on the sensor circuit.
After replacing with an "Autopart Trust Oxygen Sensors, Upstream,250-54026"
After putting in this sensor i'm now getting a check engine light for high voltage on the upstream sensor circuit and slow circuit response. P0132, and P0133
IS there something i'm missing here ?
IT appears to be the correct sensor. please help!!
thanks.....
Old Jan 13, 2017 | 03:56 PM
could be the sensor or could be an air leak or vacuum leak pushing the sensor out of range. I'd start top size and check vacuum lines/intake boots etc for anything obvious.
It looks like the OEM PN is 0651722. 250-54026 is a Walker aftermarket part number which is listed as a guaranteed fit...
You can also try clearing the codes and see if they reset.
sfruechte
Oct 21, 2015 06:06 PM
stiffy123
2001-2013 model year V70
Mar 9, 2015 06:16 PM
habbyguy
Nov 10, 2014 07:01 PM
Hugh Huntley
Aug 7, 2014 11:46 AM
sabydady
Jul 7, 2009 04:58 PM
