2004 S40 2.4i Engine
RE: 2004 S40 2.4i Engine
Engine internal is different. Forge piston is used in the turbo engine (higher cost but can withstand higher compression)and cast pistons is used in a normally aspirated engine (lower cost). If a turbo modified tointo it can cause engine to blow up! There is a reason why turbo cost a lot more than a N/A car.
