2004 Volvo s40 5 cyl bon turbo code p0303
Old Sep 17, 2018 | 10:42 PM
Imbackinthe909's Avatar
Default 2004 Volvo s40 5 cyl bon turbo code p0303
I've already checked all the other things spark plugs for coil packs all that stuff I did a compression test and my number 3 cylinder had 70 pounds and the other 4 had around 150 I did a wet test and compression only went up like 5 pounsp what's that mean
Old Sep 18, 2018 | 11:11 PM
LinkFL's Avatar
Do a leak down test. That will let you know if your problem is either an intake or exhaust valve, or worse. Did the engine have any overheat problems?
Old Sep 19, 2018 | 08:09 PM
I don't know we just bought it for my step son and after about a 100 miles the code popped up I've never done a leak down test can u maybe give me info on that I just ordered a leak down tester online but how do I preform it
Old Sep 20, 2018 | 07:29 AM
LinkFL's Avatar
Set the cylinder you are testing to TDC on the compression stroke. Screw the tester in the spark plug hole. Add about 100 psi of air and listen. Tail pipe= leaking exhaust valve, crankcase= rings or piston, coolant tank bubbles= head gasket/ head/ block. That is the basics.
You can check YouTube, that's how my kids learn everything.
Old Sep 20, 2018 | 11:57 AM
Thanks for ur help I really appreciate it alot
Chas69
Nov 8, 2017 08:50 PM
KAP
Oct 17, 2016 09:40 PM
SWH72
May 3, 2016 12:06 PM
rspi
Engine & Internal
Jan 9, 2013 08:57 AM
zerofallout
Oct 27, 2010 06:11 AM
