2005 s40
Old Apr 19, 2021 | 05:21 AM
Bigpancho's Avatar
Default 2005 s40
My 05 s40 won't start or release key. Have power .can hear clicking won't crank
Old Jun 21, 2021 | 11:33 PM
dondo3's Avatar
Default I’m having same issue
B4 It would start and then stalls out but not before the gauges went haywire! I’m still having this issue
Old Jun 22, 2021 | 08:51 AM
richardkonrad's Avatar
The starter solenoid is sticking so will need to be replaced , is a manual ? try push starting it
Old Jun 22, 2021 | 11:32 AM
If you have an automatic, check the shifter release button to see if its stuck inward - the shifter has an interlock which keeps the car from starting when it senses its not in park and will not allow the key to be removed.
Old Jun 23, 2021 | 01:05 AM
dondo3's Avatar
Default I am confused
I do have an automatic but I don’t know where to locate the shift realest button ? Is that on the shifter **** ? If so then no it’s no stuck?
Old Jun 23, 2021 | 11:06 AM
habbyguy's Avatar
Dondo3, if your car starts (or even tries to start), your interlock is fine.
Old Jun 23, 2021 | 11:15 AM
dondo3's Avatar
update!! I just tried starting up this morning and it did not crank or start !! Now my key is stuck in ignition
Old Jun 23, 2021 | 11:32 AM
You may simply have a weak/bad/almost dead battery or a poor connection to the ok battery.
Old Jun 23, 2021 | 11:33 AM
dondo3's Avatar
as I stated above I have a battery jumpstart that reads off the battery voltage for me . With car off battery reads 12.4 any other possibilities
thanks in advance
Old Jun 23, 2021 | 11:45 AM
Yes, a broken connection inside the battery. The battery is 6 cells connected by buss bars - metal connections between the cells connecting them in series. If one of those cracks maybe from thermal expansion and contraction the battery can still register 12.4 volts - but it won't be able to provide any current under load. Can you jump start the car? (using quality jumper cables)
A good next step would be to load test the battery and if ok - use a compatible scan tool to look for any electronic faults.
Old Jun 23, 2021 | 11:47 AM
dondo3's Avatar
I see interesting. This morning I went to start the car and nothing now my key fob is stuck in ignition
Old Jun 23, 2021 | 12:43 PM
habbyguy's Avatar
Hoonk is right (as usual). Throw a voltmeter on the battery and see what happens when you turn the key to the start position (don't rely on the jumper box voltmeter - it could be reading its internal battery).
nachocheese03
Dec 12, 2017 03:26 PM
matchs
Jun 12, 2012 03:32 PM
Lavid2002
Feb 27, 2011 06:07 PM
morrisamazon53
Feb 22, 2011 06:14 PM
lacie70
Oct 9, 2010 04:03 PM
