-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   2005 s40 (https://volvoforums.com/forum/volvo-s40-11/2005-s40-106087/)
Bigpancho Apr 19, 2021 05:21 AM
2005 s40
My 05 s40 won't start or release key. Have power .can hear clicking won't crank
dondo3 Jun 21, 2021 11:33 PM
I’m having same issue
B4 It would start and then stalls out but not before the gauges went haywire! I’m still having this issue
richardkonrad Jun 22, 2021 08:51 AM
The starter solenoid is sticking so will need to be replaced , is a manual ? try push starting it
mt6127 Jun 22, 2021 11:32 AM
If you have an automatic, check the shifter release button to see if its stuck inward - the shifter has an interlock which keeps the car from starting when it senses its not in park and will not allow the key to be removed.
dondo3 Jun 23, 2021 01:05 AM
I am confused
I do have an automatic but I don’t know where to locate the shift realest button ? Is that on the shifter knob ? If so then no it’s no stuck?
habbyguy Jun 23, 2021 11:06 AM
Dondo3, if your car starts (or even tries to start), your interlock is fine.
dondo3 Jun 23, 2021 11:15 AM
update!! I just tried starting up this morning and it did not crank or start !! Now my key is stuck in ignition
hoonk Jun 23, 2021 11:32 AM
You may simply have a weak/bad/almost dead battery or a poor connection to the ok battery.
dondo3 Jun 23, 2021 11:33 AM
as I stated above I have a battery jumpstart that reads off the battery voltage for me . With car off battery reads 12.4 any other possibilities
thanks in advance
hoonk Jun 23, 2021 11:45 AM
Yes, a broken connection inside the battery. The battery is 6 cells connected by buss bars - metal connections between the cells connecting them in series. If one of those cracks maybe from thermal expansion and contraction the battery can still register 12.4 volts - but it won't be able to provide any current under load. Can you jump start the car? (using quality jumper cables)
A good next step would be to load test the battery and if ok - use a compatible scan tool to look for any electronic faults.
dondo3 Jun 23, 2021 11:47 AM
I see interesting. This morning I went to start the car and nothing now my key fob is stuck in ignition
habbyguy Jun 23, 2021 12:43 PM
Hoonk is right (as usual). Throw a voltmeter on the battery and see what happens when you turn the key to the start position (don't rely on the jumper box voltmeter - it could be reading its internal battery).
