2006 s40 ecm
Old Jun 9, 2021 | 11:12 AM
cold1kemp@gmail.com's Avatar
Default 2006 s40 ecm
I keep blowing the 02 sensor fuse. The sensors have been replaced and we can't find any bad wiring. The next option was to repair/ replace the. ECM. I can't find any videos or photos of where the part is located on the car. Any help here would greatly appreciated.
Old Jun 9, 2021 | 01:08 PM
If you are replacing fuse 33 in the fuse box under the hood that powers the O2 sensor heaters - That fuse powers the vacuum pump also. Does your vacuum pump work? 8/84 is the vacuum pump switch, 6/114 is the pump, 7/15 and 7/82 are the O2 sensors.
Old Jun 12, 2021 | 08:22 AM
I don't think I'm having any issues with that. What would be the symptoms be?
Old Jun 12, 2021 | 09:02 AM
The vacuum pump does not work. The switches commonly break and make the pump run until it seizes up and possibly shorts out. Then it blows the fuse (#33 in the diagram that also powers the O2 heaters.)
To test: Turn ignition on, don't start car. Pump the brake pedal - if it gets hard after a few pumps - the vacuum pump is not working. If it stays the normal soft feel - the vacuum pump is working. Or find and visually inspect the switch and pump - you can jump across the two wires in the harness to the switch to manually run the pump. If it takes a while to blow the fuse - just unplug the vacuum pump switch to prevent current from going to the pump - and see if the fuse continues to blow.
Old Jun 12, 2021 | 09:20 AM
So if the brake gets hard, then do i need to replace the vacuum pump or is this a sign of the ecm going out?
Old Jun 12, 2021 | 12:24 PM
If the vacuum pump does not work - you need to figure out why. (is it seized, is the switch is bad - or there's no power to the switch because of a problem with other items on the fuse causing it to blow, etc.) The ECM has nothing to do with the vacuum pump. Stop thinking about a bad ECM - you don't want that to be the cure, it's not a common failure. You may have already replaced O2 sensor you did not need to - so
Look at the wiring diagram. Power goes from fuse 33 to the vacuum pump switch, which if turned on (due to low vacuum in the connected hoses or a broken switch) sends power to the pump, and the pump is grounded completing the circuit.
How long does it take before fuse 33 blows?
Old Jun 12, 2021 | 12:43 PM
Vacuum pump was working. Found out that the wrong size fuse installed. Replaced the fuse, reset the check engine light. I drove it for 60 miles and no light. It passed inspection.
Philip152
Jul 13, 2024 11:53 PM
Ceil Garber
May 25, 2019 08:49 AM
adfrey
Sep 27, 2016 05:20 PM
jinsoopark
Jul 9, 2014 01:18 PM
aromano93
Sep 2, 2009 08:29 PM
