2006 S40 Instrument Panel has stopped working
Old Oct 23, 2015 | 03:45 AM
fontofontaine's Avatar
Default 2006 S40 Instrument Panel has stopped working
Hi All,
I have recently purchased an 06 Volvo S40 SE. I've noticed a couple of little electrical issue since I've bought it and today it's gotten even worse.
Issues I've noticed in order:
Passenger side front and rear doors not locking
Passenger side front and rear windows not opening/closing
(Above are intermittent)
Last couple of days things have gotten worse.
Instrument Panel stared popping up messages at times like:
"Brakes failed. Please stop carefully"
"SRS Airbag needs urgent service"
Then this morning on the drive into work the whole Instrument Panel turned off. So I have no speedometer, temperature gauge, mileage display, etc.
The lights on the car still work, as do the indicators, radio, aircon, and electric windows.
So the problem appears to be the instrument panel. Has anyone experienced similar, and if so, can you recommend a fix?
Thanks!
Old Feb 22, 2022 | 07:13 AM
Olisen's Avatar
Default Exactly the same problem
Originally Posted by fontofontaine
Hi All,
Thanks!
Hi
I now suffer from exactly the same problem! Did you find any solution for this ?
Old Feb 22, 2022 | 10:10 AM
habbyguy's Avatar
With nearly any car, when you start losing multiple, seemingly unconnected systems, you've got a voltage problem (most likely because of a bad alternator).
This is where it's good to have a multimeter so you can check your battery voltage (should be 12 volts with the engine off, and around 14 volts with it running).
Old Feb 24, 2022 | 07:30 AM
richardkonrad's Avatar
100% but the voltage should be 12.6 Volts , if its only 12 then the battery is flat , thats with engine off
Old Feb 24, 2022 | 11:37 AM
habbyguy's Avatar
I've found that the resting battery voltage varies quite a bit, even with a good battery. 12.6 volts sounds reasonable after shutting the engine off after a prolonged drive, but by the next (especially cool) morning, it's going to be closer to 12 volts. And I'm betting with the OP's car, the voltage will be considerably lower! ;-)
Old Feb 25, 2022 | 10:03 AM
No anything lower that 12.3 will cause problems , a good battery should keep 12.6 for at least a week
But there are many diffened bateries around best is to check it under load like starting a car , good one should drop to 10-11 volts , bad one to less or even 0, if its less than 9v the battery is gone
benchapp
North East
Jul 11, 2024 07:37 AM
jmana
2001-2013 model year XC70
Mar 2, 2017 06:03 PM
erniekcet
Jan 23, 2011 02:05 AM
celjock
Aug 8, 2009 11:04 AM
s3r4ph
Jun 19, 2009 08:39 AM
