2009 S40 waterfall console
Old May 29, 2018 | 04:29 PM
GlenRak's Avatar
Default 2009 S40 waterfall console
How do I get to the lower screws to remove the waterfall console? I removed the display and the top screws but I can't access the lower ones.
Old May 30, 2018 | 12:21 PM
Hudini's Avatar
See the little panel holding the power adapter at the base of the shifter? You will find the screws underneath. Carefully pry the small panel up and disconnect the power supply.
Old Dec 31, 2020 | 07:28 PM
Paul Chapman's Avatar
On the 2008-2012 Model S40 (Facelift) the floor console was redesigned. Access to the two lower waterfall console screws require you to undo the screws and clip securing the floor console and sliding the floor console backwards about 30-40mm or so to get to the two lower screws.
See the video here
Argievolvo
Feb 16, 2017 09:56 AM
mstrplmber
Mar 18, 2013 02:51 PM
wolkster
Feb 22, 2011 06:44 PM
bt260
Apr 19, 2010 07:23 AM
740TurboGuy
Apr 18, 2009 07:19 AM
