battery
Old May 25, 2009 | 09:56 PM
fleshbone's Avatar
Default battery
Do you know how do you get the battery out of a Volvo s40 to change it?
________________
Like a cop car. Got corsa exhaust Mrs. Officer?
Old May 25, 2009 | 10:01 PM
There is a battery tie down on the front side close to the motor.
You lift up the tie down then work the battery out.
Do you have the foam cover over the battery or the felt one?
If you have the felt one first disconnect the battery cables and slide the felt part out then you should see the tie down then you can remove it.
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
cmercon
Feb 2, 2009 02:15 AM
ahn2u
Feb 25, 2005 11:20 AM
dkhorne
Feb 11, 2005 10:02 AM
