Belt Noise
Old Aug 2, 2015 | 10:50 AM
haleyvolvo's Avatar
Default Belt Noise
2005 S40 41k. Picked a belt noise can figure out A/C or Alternator. Video would upload/ Only Happens when car is warmed up and doesn't matter if A/C is on. any advise to pinpoint the issue?
Old Aug 2, 2015 | 01:08 PM
My experience is most belt noises are from the idler wheel/tensioner parts versus the components. You can see if the noise changes when you engage/disengage the AC, or when you put a load on the alternator (ie turn on lights/blower/rear defroster/seat heater etc). The next step would be to use a mechanics stethescope to see if you can listen to a specific pulley or area. Finally you would need to pull off the belt, inspect it and manually turn the idler wheels/tensioner wheel to see if something feels like its dragging or has play in it.
Old Aug 2, 2015 | 04:03 PM
haleyvolvo's Avatar
Thanks, Looks like I'll be getting a new alternator!
Old Aug 2, 2015 | 06:03 PM
when you go to install the alternator, you should consider checking and replacing the tensioner and idlers as well...
Old Aug 2, 2015 | 07:30 PM
ES6T's Avatar
Sure it's not the PCV?
Old Aug 5, 2015 | 12:00 AM
Vida's Avatar
He has to pull the dipstick if that's the case. Think with your dipstick haleyvolvo lol
kags1969
Jun 24, 2010 03:24 PM
iscwebe
Feb 9, 2010 12:50 AM
reedkm
Sep 22, 2009 07:42 PM
boulwie
Dec 23, 2007 11:41 AM
