BOV
Customize a BOV? What do you mean?
1. What model s40 do you own?
2. What is your buget like?
3. You have two options to mount the BOV.
OPTION (1):[/b] Mount it to your Upper IC Pipe. This can be only done if your Upper IC Pipe is made from Aluminum as you will need an Aluminum adapter to weld onto the Aluinum Upper IC Pipe. Then you attach the BOV to the adapter (Flange) and run a vaccum line.
This is my BOV that is attached to my Upper IC Pipe on my 1999 s70 awd.
OPTION (2): You can get a T-Adapter and attach your BOV to your Upper Intercooler Hose. This is done by cutting your Upper Intercooler Hose in half and inserting the T-Adapter into the hose and putting a hose clamp on either side to keep it nice a tight and so it doesn't leak. Then you attach the BOV to the exposed end of the T-Adapter and then run your vaccum line.
Like these
http://cgi.ebay.com/ebaymotors/2-25-...28636065QQrdZ1
http://cgi.ebay.com/ebaymotors/HKS-B...26185010QQrdZ1
http://cgi.ebay.com/ebaymotors/3-ALU...24499035QQrdZ1
These are your two options. On a side note you may want to block off your stock CBV which is like a BOV but it isn't. This can be done by buying a blanking plate from IPD, or a few people on Volvospeed sell them as well. I also think QuickBrickMotorSports sells them. Once this is blocked off you can run the vaccum line that was running to the CBV to the BOV. And you should be set. This doesn't have to be done but it is a good idea.
4. I recommend a HKS SSQV. The Turbo XS Type H-RFL is known to leak.
Like these
ORIGINAL: vovonub
thanks and how much will this alter the sound of the exhaust
so what will it alter in the car?? where does the vacuum hose run to from the BOV?? and thank you for helping me on this situation. i do not know much but i am learning. My older brother has a modified golf GTI turbo. in a few weeks i will post a picture of my volvo when i have modified it a little.
It looks like a HKS SSQV, but it isn't. Neither it is a replica.
SSQ is twin chamber, this is single chamber.
It is Simoni Racing BOV: http://www.simoniracing.com/us/index.php
And I can adjust the settings when the valve opens via screw on the valve... testing it today.
if you only want a BOV cause you want to hear that turbo spooling sound, you might as well not waster your money and just get an EST intake....our turbos have CBV's rather that BOV's and its really not a mod that will benefit you in anyway...
ORIGINAL: mcguij1
I have had both a BOV and the EST intake for my s70. I'd say go with EST intake as well. BOV is neat but not worth it.
Yea I only want one for the ppssshhhhhhhhhhhh sound. i was gonna get one off Ebay for cheap....... do you know what that little airfilter does on the left of his airbox??..... I already made a set up on my stock airbox so it gets nice cold air from the front of my car.....
Also do you know the diameter of the IC hose that connects to the radiator
ORIGINAL: chimmychong
Also don't buy cheap off EBAY. You get what you pay for and trust me if you pay cheap your going to get cheap.
I believe that is a breather filter and is required if you mod your intake from the OEM setup.
