Brake Leak Help
Old Nov 19, 2008 | 06:03 AM
ndloewen's Avatar
Default Brake Leak Help
I got in my 2000 s40 1.9T and the brakes pushed very easily all the way to the floor then the brake light came on I checked my fluid it was low in the resevoir so I added some more. I went back to the car later to see a puddle of brake fluid under the car. I had my wife push the brakes so I could see where the leak was and it was shooting out near the pads. Has anyone had this problem? And can a simple hose replacement work?
Old Nov 19, 2008 | 07:29 AM
Default RE: Brake Leak Help
You will have to pull the wheel and inspect and see if it is the hose or caliper.
Old Nov 19, 2008 | 07:43 AM
ndloewen's Avatar
Thank you it is the front brake hose leaking at the fitting. I have one ordered from a parts store im in the middle of no where so it takes about a day for it to get here.
Old Nov 19, 2008 | 07:59 AM
Hopefully you get it soon and get it all fixed.
dlleo
Feb 29, 2012 05:31 AM
agardin10
May 22, 2011 10:52 AM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
my850turbo
Jun 27, 2006 01:29 AM
