Brake pad thickness
Some brake pads have a line cut down the middle of the pad. When the line is gone it is time to change the pad. Some have little metal tabs that show when it is time for a change.
Are you just wondering or do you think it is time for a pad change ? How many miles are on the pads ? In most cases the front pads will need to be changed before the back. Also.... bleed the system a little while you are at each wheel. DO NOT BACK BLEED THE BRAKES........
Cb
Cb
