Broken Hose
Our 2001 S40 can't turn over completely !
We have change the following: spark plugs coils and wires fuel filter air filter maf sensor fuel pressure regulator and it still will not stay started Question : I recently seen a broken cracked off black hoes about 3/4 inch in diameter coming from a outlet under the air idle valve and coming up to a pocket inlet above the radiator. Would this cause the car not to start ? Also can somebody tell me what this hose does and the proper name for it ? Thanks |
I think the hose is the Idle Air Control Valve Hose now .
I still don't know the function of it and if would make the car not start or stall. |
Yes, it will make the car not run correctly. My 2001 broke this same hose and I could only find an exact replacement at the dealer. It's simple and fast to change though.
Thanks , I've now changed the idle air control hose and air idle valve and the car is running good . Drove the ride most of the day now check engine light on but only for bank 1 oxygen sensor slow response . I guess that's next .....
