Broken Hose
Old Oct 9, 2011 | 01:08 PM
Flawsey's Avatar
Default Broken Hose
Our 2001 S40 can't turn over completely !
We have change the following:
spark plugs
coils and wires
fuel filter
air filter
maf sensor
fuel pressure regulator
and it still will not stay started
Question : I recently seen a broken cracked off black hoes about 3/4 inch in diameter coming from a outlet under the air idle valve and coming up to a pocket inlet above the radiator.
Would this cause the car not to start ?
Also can somebody tell me what this hose does and the proper name for it ?
Thanks
Old Oct 9, 2011 | 05:01 PM
Flawsey's Avatar
I think the hose is the Idle Air Control Valve Hose now .
I still don't know the function of it and if would make the car not start or stall.
Old Oct 9, 2011 | 08:49 PM
Hudini's Avatar
Yes, it will make the car not run correctly. My 2001 broke this same hose and I could only find an exact replacement at the dealer. It's simple and fast to change though.
Old Oct 10, 2011 | 03:32 PM
Flawsey's Avatar
Thanks , I've now changed the idle air control hose and air idle valve and the car is running good . Drove the ride most of the day now check engine light on but only for bank 1 oxygen sensor slow response . I guess that's next .....
91shelby
Feb 7, 2022 10:52 AM
tomecsi
Oct 27, 2011 07:56 PM
tucker98
Nov 11, 2009 04:16 PM
Volvo850GLTOwner
Sep 24, 2007 03:44 PM
tupapison
Jul 1, 2006 07:03 PM
