Can't stop fan
My 2001 S40 has a fan problem. The fan is blowing out air constantly, and I can't stop or turn it off. Air and heating are working fine, but blowing out a lot of air. What can I do?
RE: Can't stop fan
When you turn the fan switch to low nothing happens?
RE: Can't stop fan
The fan switch is not working. I cannot stop the fan. It's belowing a lot of air and very noisy. It gets even worse when I turn on AC.
RE: Can't stop fan
Sounds like the climate module is bad.
RE: Can't stop fan
Help! I am having the same problem. My Volvo’s Blower Speed suddenly only operates Full speed as soon as the ignition is switched on.
How much will this fix cost? Was it the climate module afterall? If so, can I replace the climate module myelf? |
RE: Can't stop fan
I know this is old but did you ever get a solution to the blower issue?
RE: Can't stop fan
ORIGINAL: rjolly Help! I am having the same problem. My Volvo’s Blower Speed suddenly only operates Full speed as soon as the ignition is switched on. How much will this fix cost? Was it the climate module afterall? If so, can I replace the climate module myelf? Many thanks. |
RE: Can't stop fan
Check s40concepts.net, theres a howto for fixing this problem titled "AC BLOWER FAN THAT RUNS HIGH ALL THE TIME".
