Can't stop fan
Old Sep 29, 2005 | 03:15 PM
hskim's Avatar
Default Can't stop fan
My 2001 S40 has a fan problem. The fan is blowing out air constantly, and I can't stop or turn it off. Air and heating are working fine, but blowing out a lot of air. What can I do?
Old Sep 29, 2005 | 09:44 PM
Default RE: Can't stop fan
When you turn the fan switch to low nothing happens?
Old Sep 30, 2005 | 11:47 AM
hskim's Avatar
The fan switch is not working. I cannot stop the fan. It's belowing a lot of air and very noisy. It gets even worse when I turn on AC.
Old Sep 30, 2005 | 09:20 PM
Sounds like the climate module is bad.
Old Feb 10, 2006 | 03:17 PM
rjolly's Avatar
Help! I am having the same problem. My Volvo’s Blower Speed suddenly only operates Full speed as soon as the ignition is switched on.
How much will this fix cost? Was it the climate module afterall? If so, can I replace the climate module myelf?
Old Jun 19, 2007 | 09:35 PM
Calandrelli's Avatar
I know this is old but did you ever get a solution to the blower issue?
Old Dec 12, 2008 | 10:30 AM
mariewow's Avatar
ORIGINAL: rjolly
Hi, I know this was posted a while ago, I jut wondered if you ever fixed the problem as my Volvo S40 2003 is doing the same thing and I need to get it fixed (as cheap as poss) can you help?
Many thanks.
Old Dec 12, 2008 | 10:45 AM
mrneb's Avatar
Check s40concepts.net, theres a howto for fixing this problem titled "AC BLOWER FAN THAT RUNS HIGH ALL THE TIME".
Volvo850GLTOwner
Oct 10, 2012 10:08 PM
gclin
Mar 23, 2012 12:45 PM
pnhons
Nov 20, 2011 05:26 PM
LSE
Mar 5, 2006 10:51 PM
