Car won't start & i get this message Anti Skid Service Required
Old Jun 16, 2012 | 02:43 PM
Barbie's Avatar
Unhappy Car won't start & i get this message Anti Skid Service Required
Hey everyone,
I have a 2008 s40 that i bought a few months ago in December.
This issue has happened twice.
The only connection I can make is it happens a few days after iv had an oil change.
It starts off with the car not starting in the afternoon when leaving from work. It will not even attempt to start or make any noise.
The first message reads "immobilizer please restart"
So i continue to try and start the car. No success.
Then the message will change by the third attempt to "anti skid service required"
I keep trying to start the car, and usually after 7-9 attempts it starts right up.
Like I said this has happened twice, and never in between.
Does anyone have an idea of what could be causing this?
Im very protective of my car and make sure it gets top service when as soon as possible. Im scared its going to ruin my car if I don't get the problem fixed.
Old Jun 16, 2012 | 02:54 PM
jujudude's Avatar
most of the time that is a abs problem but im no mechanic... take it to a dealer and have them look at it. do u live near Ontario?
if so the guy who owns the ontario volvo dealership in the autoplaza is my uncle.
Old Jun 16, 2012 | 02:58 PM
jujudude's Avatar
9096055700 is the phone number
Old Jun 17, 2012 | 12:11 PM
Barbie's Avatar
That was my first thought, that something is up with the brakes.
Unfortunately, I live near Sacramento. Turner Volvo is the closest, and actually only volvo dealer that i know of around me.
Old Jun 20, 2012 | 06:43 PM
dazdjc's Avatar
I'll never buy another Volvo. I have a 2002 Volvo XC90 and have had problems with it for years. Practically everything has been replaced (including gearbox). Anti skid warning is up...again. Just had to order a new sunroof rubber seal to the price of £110. A locking nut was going to cost £50. I paid approx £500 for a new cd multi-changer from them...and then they wanted over £100 to install it!...Absolute joke. I agree that they have overheads and need to make a profit, but its been daylight robbery from the start.
Old Feb 1, 2013 | 04:32 AM
s60t's Avatar
any idea what was the matter ?
my s60 wont start and I have the same msg anti-skid service requierd
Old Feb 1, 2013 | 05:43 AM
Hudini's Avatar
A weak battery will cause all kinds of havoc to the electrical system. Do you know how to jumpstart a car? Try that and see if it starts. Seriously, low voltage will cause all kinds of strange behavior.
Old Feb 1, 2013 | 08:33 AM
s60t's Avatar
I had this battery 6 month back , the lights horn AC every thing is working ok and when I try to start it the sound of the starter is ok also but the car wont start at all
Old Feb 2, 2013 | 02:51 AM
Barbie's Avatar
Is it making any noise at all?
Fortunately, this has not happened to me since i posted this. However, when it was happening, i just kept trying to start it and by the 10th time or so it would start up.
I do not know how to explain the sound i heard, but it was a soft humming sound, almost like the sound a computer makes when its running.
I just had mine in the shop for an alignment and they did a full inspection and did not find anything wrong with my brakes or such.
Honestly the only issue with my Volvo is I am losing oil, they suspect sooner than i should so they replaced my engine filter and did a software update.
The software update HAS changed my cars alert system.
for example: if i do not put my seat belt on, it no longer beeps until i do, i dont know if this can have anything to do with it.
Old Feb 3, 2013 | 01:46 AM
s60t's Avatar
noise no , the starter sound is normal , i am in kuwait (middle east ) and mechanics her have no idea about these stuff , for me the car is finished now , i am trying to find a way to bring it back to life , the problem its not starting at all i tried 10 times starting it and that caused the battery to bie , i replaced the battery and waiting a Miracle now
Old Feb 3, 2013 | 02:25 AM
Hudini's Avatar
Have you checked the fuses? How about fuel pressure? You wrote that the starter sound is normal which means to me the engine is turning over but is not starting up? Have you checked the timing belt? Checked for compression? This is a regular double overhead cam engine with a single timing belt. All the normal tests for a car engine apply. It must have fuel and spark and proper timing.
Old Feb 4, 2013 | 09:58 AM
s60t's Avatar
timing belt ok , but the mechanic found 1 plug socked in oil , could that cause yhe ECU to shut ???
Old Feb 4, 2013 | 05:51 PM
Hudini's Avatar
Not in my experience. Does the car have spark? Fuel pressure?
DPW-CT
Mar 3, 2021 12:12 PM
drewmun247
Mar 20, 2019 10:01 PM
giannis-21
Aug 10, 2011 01:50 PM
akirk6884
Jan 16, 2007 12:23 AM
