CEL P0234 code
Old Dec 21, 2015 | 01:15 PM
Newport_j's Avatar
Default CEL P0234 code
My check engine light came on yesterday on my 2002 Volvo s40 and I put the OBD II on it. The code is P0234. What is the issue here? Can I determine cause by just how car runs?
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Old Dec 21, 2015 | 09:36 PM
Leftlanetruckin's Avatar
Enter the code in the search box in this forum.
You will get results like this thread
https://volvoforums.com/forum/volvo-...de-only-66496/
From Alldata, regarding that code...
Signal too high:
  • The boost pressure control (BPC) valve has stuck in the closed position
  • Leakage in the hoses for the boost pressure control (BPC) pressure regulator
  • Defective boost pressure control (BPC) valve pressure regulator
  • Defective mass air flow (MAF) sensor.
Martin
Old Dec 22, 2015 | 09:00 AM
Newport_j's Avatar
Thanks.
I have been having trouble with the MAF sensor. Is this the most common problem with p0234 codes or is it something else?
Thanks in advance.
Respectfully,
Newport_j
Old Dec 22, 2015 | 10:00 AM
How do you mean you've been having problems with the MAF sensor??
It needs to be tested, or you can unplug it and go from there , after you see what happens then.
The BPC is also a likely culprit.
It's next to impossible to diagnose over the internet, and not 100% right all the time when the vehicle is in someones hands who knows what they are doing
Martin
Old Jan 12, 2016 | 11:54 AM
Newport_j's Avatar
What is the part number for the BPC. Where is it located on a Volvo s40? I do not know whether to replace it or repair it.
What is the part number of name for the BPC the boost pressure control valve?
If it is cheap and easy to replace then I should replace it. The CEL light comes on periodically and goes off periodically. I am just wanting tis repaired.
Respectfully,
Newport_j
Old Jan 12, 2016 | 05:54 PM
Old Jan 14, 2016 | 03:44 PM
Newport_j's Avatar
Default Reapir Procedure for P0234
I guess the logical response for this code (P0234) is to replace the Boost Pressure Valve. That seems easy enough.
Now if that does not shut the light off then maybe I should look at number 2. which is the hoses that connect the Boost Pressure Control valve. Is that correct,
The final thing to check is the MAF sensor. Correct?
Respectfully,
Newport_j
Old Jan 14, 2016 | 04:50 PM
my work sequence would be a) check hoses/boots and vacuum lines b) clean MAF, idle valve, intake with MAF cleaner c) test what parts you can.. ie measure voltages on the MAF etc d) order/replace most likely suspect... just be careful with MAFs - some models are very sensitive to after market "near" fits. You may want to go OEM if it turns out to be the MAF or shop where you get a "guaranteed fit"
Old Feb 1, 2016 | 08:00 AM
Newport_j's Avatar
I will start by replacing the boost pressure control valve. I just need to know the part number for one for a 2002 Volvo s40. Also, does this valve come with the hoses or do they need to be bought separately?
Thanks in advance.
Respectfully,
Newport_j
Old Feb 1, 2016 | 08:07 AM
Hudini's Avatar
Take a look at the one from IPD. (I don't get anything from them)
(BCS) Boost Control Solenoid GENUINE VOLVO 115605 9473212
It looks like you do not get hoses. You can always call their tech department to get helpful advice.
Old Feb 4, 2016 | 08:24 AM
Newport_j's Avatar
Default I foudn the part now I need to get the hose
Okay, it looks like the correct part, but I do not get hoses.
The question is what type of hose do I need and how long should it be?
I found a sample hose at the same website you showed me, it has a part number 121613.
It is 5 mm ID. Is his the right one for a 2002 Volvo s40?
Respectfully,
Newport_j
Old Feb 4, 2016 | 12:33 PM
diagrams etc can be found on some of the dealer web sites ie tascaparts.com and volvopartswarehouse.com. I also find the folks at FCP good for tech questions.
Note VPW shows the valve for $66 and the hoses as needed.
Old Feb 7, 2016 | 12:53 PM
Newport_j's Avatar
Default Need info on FCP
What is the phone number or website address for FCP?
Respectfully,
Newport_k
Old Feb 7, 2016 | 02:48 PM
https://www.fcpeuro.com/Volvo-parts/
Newport_k, Please stop double spacing between sentences. Just takes up extra room.
Old Mar 10, 2016 | 08:35 AM
Newport_j's Avatar
Default The BPV replacement worked, but CEL is now back on
Damn!
I thought that I had it. I installed a new BPV on my 2002 Volvo s40 and it seemed to work.
The car had pep and it did not display any check engine light. That worked for almost 3 weeks. Then - boom - the check engine light came back on.
I have not checked the code, but it is probably p0234 or p0101.
I guess the next job is to check the MAF sensor hoses and to clean the MAF sensor.
Is this a logical step to make. As I said I replaced the BPV, but the check engine light came back on after about three weeks.
Respectfully,
Newport_j
Old Mar 10, 2016 | 09:14 AM
did you check for vacuum leaks or leaks on the boost side of things? Another possible cause could be the MAP sensor (air pressure sensor - not the MAF air flow sensor which meters fuel to air ratios)
Old Mar 10, 2016 | 09:38 AM
  #17
Newport_j's Avatar
Default I will give those items a check
I will check what you stated. thanks ofr the heads up.
Respectfully,
Newport_j
Old Mar 25, 2016 | 12:16 PM
  #18
Newport_j's Avatar
What is a good brand and price for the MAP (as you said it is not the MAF)? I have seen prices all over the place.
Respectfully,
Newport_j
Old Mar 25, 2016 | 08:14 PM
  #19
Re shopping for a MAP sensor: eeuroparts.com has a Bosch for $50 and Volvo OEM for $100. If you want Volvo OEM, Tascaparts.com is probably the best price.
Old Jul 1, 2016 | 12:32 PM
  #20
Newport_j's Avatar
Default Biying and Installing the MAP sensor
I am not sure if there is a difference between the Bosch MAP sensor and the original equipment Volvo MAP sensor except in the price. Is there?
Also, where are the instructions on installing the MAP sensor?
Respectfully,
Newport_j
hamburglar
May 9, 2013 11:30 AM
eewhiz
Oct 26, 2012 09:12 PM
mark458
Sep 29, 2010 07:34 AM
cowenstaff
Nov 2, 2009 06:00 AM
Anns V70
Sep 7, 2006 11:53 PM
