Center Hub Caps/Wheel Caps
Can someone please tell me what size Center Wheel Caps does a 2000 Volvo S40 2.0 take? Internet says 60mm, I've measured and it's 57mm, yet some say it's 64mm.
Depends on the rims. https://www.fcpeuro.com/products/vol...wE#description
Those are for the 6" x 15" rim |
Originally Posted by Dingus1
(Post 510099)
Those are for the 6" x 15" rim https://cimg7.ibsrv.net/gimg/volvofo...386a84ab96.jpg |
Why not just measure the hole (corresponding with the diagram Dingus1 provided)? Seems a whole lot easier than trying to track down info on long-discontinued factory rims.
Originally Posted by habbyguy
(Post 510113)
I was hoping someone owns a 2000 Volvo S40 which has center caps and would be able to assist after measuring theirs. Here in South Africa, it is 400zar which is roughly 28 dollars for the set of 4, which is why I want to make sure I get the right size. |
(Post 510113)
Volvo only shows 1 center cap for the Gen 1 S40s: PN# 30638643 PS your wheels are called "Spectra" $10.85 at Tasca Parts (a dealer web store)
https://www.tascaparts.com/oem-parts...r-cap-30638643 I'll be doing a snow tire change on my 2000 s40 over this weekend and can snap a pic. I run 15" Spectras for the snows and Gallatica 16" for the summer - the cap fits both. |
Originally Posted by AryannS40
(Post 510122)
To add to that, do I go with 55mm or 60mm when ordering? Since the inner diameter is smaller than than the outer? 55mm is the closest to 57mm as supposed to 60mm.
I wonder if he's measuring the inside diameter of the "big hole" (outside) or the "little hole" (inside) at 57mm.
Originally Posted by mt6127
(Post 510125)
(Post 510127)
The 55mm and 60mm are measuring 2 different parts of the same cap. So like mt6127 mentioned and linked the same part i did, but cheaper, i would go with those which are 60mm. If you measured where the cap goes and got 57mm. sounds like they left 1mm clearance on either side.
(Post 510128)
To note, the OEM part number here is 30821245. That should be all you need to know. I don't own a micrometer/ inside caliper to extactly if the OD is 59 or 60mm but its very close.
https://cimg7.ibsrv.net/gimg/volvofo...ae7890f98e.jpg |
(Post 510583)
When I had mine some years back I also lost 2 , also in RSA not sure if stolen or just came of , I replaced all 4 with caps from some container , they were black and looked ok , cant remember what container it was but just cliped in and never came off , or stolen until I traded it in on the T5 , wish I had a pick of it , as to replace then was a lot more , If I recall was like R600 each! Which I thought was madness
Originally Posted by richardkonrad
(Post 510621)
Ebay and Wish has the same sizes available as the OEM but my main worry is the quality. |
Avoid Wish, and for Ebay it depends on the seller as far as quality goes. If they are sending you an OE part then I wouldn't worry too much.
(Post 510653)
Just wanted to share. I received the Center Caps from WISH. It is absolutely brilliant quality. Picture for reference.
Came with the steel lock ring as well. https://cimg0.ibsrv.net/gimg/volvofo...898235d913.jpg |
