Check Engine Light P0130
Old Nov 11, 2006 | 10:36 PM
volvo94404's Avatar
Default Check Engine Light P0130
I have a 2000 S40 and my check engine light keeps going on and off. I got the code pulled when it was ON and found out it was P0130 for Oxygen Sensor Bank 1. I understand there are 2 O2 sensors one is called front and other is rear, atleast thats what i found when i was searching for Oxygen sensors online. Is the code P0130 for the front or the rear O2 sensor? Where would i get it? Would Online be better than dealership? Should I consider universal O2 sensors as they seem to be cheaper? Aay advise is appreciated
thanks
Old Nov 12, 2006 | 12:15 PM
Default RE: Check Engine Light P0130
That code should be the front o2 sensor.
I would only buy a Bosch sensor.
Old Nov 13, 2006 | 02:02 PM
volvo94404's Avatar
Thanks tech
Can some one please tell me where the front O2 sensor is located for a 2000 S 40? Is it easy to replace?
Appreciate the responses
thanks
Old Nov 14, 2006 | 08:42 PM
It is pretty easy to replace.
Look at the exhaust starting at the engine follow back and look for a Nut looking thing with wires coming out that is the front O2 sensor should be about 8 inches to a foot from the engine.
Old Nov 19, 2006 | 08:00 PM
skatermattc2's Avatar
I too have this problem with the p0130 (o2 sensor circut malfunction "bank 1 sensor 1") code. It went off three times in two weeks. Any thoughts on what the problem could be? Could the o2 sensor be bad? My plugs aren't that old and my coils are brand new. The car seems to be running fine. Thanks for the help.
2001 volvo s40 1.9t
Old Nov 21, 2006 | 12:21 AM
volvotechky's Avatar
i beleive that code comes up ECM 16, there is a bulliten on that DTC, there is a harness and a ECM update download that should cure the problem..
If this has already been done than the front O2 will need to be replaced.. very accessable
Old Nov 24, 2006 | 10:45 AM
ORIGINAL: volvotechky
+1
Old Dec 12, 2006 | 02:22 PM
Thanks guys. I replaced the front o2 sensor with ease. I am going to estimate my gas milage now and hopefully that darn check engine light stays off. Thanks again...Skatermattc2
mtatro
Jun 8, 2012 04:38 AM
smithnr
Jun 20, 2011 02:28 PM
yagton
Oct 5, 2010 10:35 AM
ajwgator
Oct 4, 2010 09:50 AM
Nand12
Dec 30, 2006 12:42 PM
