Code getter question?
Old Jan 30, 2006 | 10:54 PM
skatermattc2's Avatar
Default Code getter question?
My check engine light comes on quite often on my 2001 volvo s40, and to have volvo diagnose it they want $200. I hear that I can get a code puller from Autozone. Now my question is: if I pull my codes with a code getter what do I do next? How or what do I compare my codes to to find out why my check engine light is coming on? Thanks
skatermattc2
Old Jan 31, 2006 | 12:31 AM
Default RE: Code getter question?
Alot of times the scanner will come with a book that somewhat helps you in the right direction.
Old Jan 31, 2006 | 02:40 AM
Thank You I will rent the code getter tomorrow.
Old Feb 1, 2006 | 04:08 PM
06txs40's Avatar
Autozone will plug it in & tell you what codes are coming up on the spot. Shouldn't have to rent. At least you don't here in TX. You can search on internet for Volvo DTC codes & go through the results until you find one that will give summary of possibilities that will point you in the right direction. Be aware that just because you have the code & where it came from, there may be 100 reasons that it got the code unless it is just general failure of a sensor. If you get a code from a certain sensor, there may be upstream or downstream problems making the sensor throw the code.
Old Feb 1, 2006 | 04:15 PM
mo t5's Avatar
I had mine checked at Autozone and they refered to a data base they had and gave me an idea of what it was. After you have that you can post it and i'm sure someome will have had that problem and can steer you in the right direction. Good luck.
91shelby
Feb 4, 2011 08:24 PM
Elsid
Sep 9, 2010 08:42 AM
mfroese
Jan 6, 2009 12:02 PM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
