code PO128
just purchased one of those obd2 readers
and the code that came up was po128 ( which in the manuel states coolant thermostat (coolant temperature below thermostat regulaing temperature)
cleared the code, not sure if i should of as now the engine light is off
- what does the code mean,,,what should i do,,change thermastat etc
anyone
2002 s40 volvo turbo automatic 90,000 kms
anyone
It is pretty easy to do. Follow the upper radiator hose to the engine. It is under that cover that the hose attaches to.
Check out this site for prices.
http://www.swedishpartswholesale.com/
if the thermostat is bad it will not let the water flow making engine overheat... if coolent temp censor is bad usually your fan will not work right you will run extremely rich and can cause vehicle to overheat also i just repalced therm on my s80 like 1 hour job make sure to drain water from lower raidiator and make sure car iss cool or you will have a red hand
censor runs bout 60-70 $ therm like 35 not to bad very easy replace
P.s. if censor is bad the gauge in car can read incorrect can say middle and actualy be red hot
![Frown](https://volvoforums.com/forum/images/smilies/frown.gif)
I am having this same issue. I have purchased a thermostat and tried to install it, but the bolts holding the cover on will not budge. A local shop has said 65 bucks to do it, should I just have them do it or keep trying to get the bolts out? I was also thinking that I should maybe go ahead and get the temp sensor too since the antifreeze is so expensive. The shop said they couldnt put anything except Volvo antifreeze in it, so I bought that today for $33. Any thoughts???
THANKS!
THANKS!
