Which cylinder is which?
Old Jun 16, 2009 | 09:23 AM
schoolloans's Avatar
Default Which cylinder is which?
Think I have a bad coil (misfire, cylinder 3). Is it 1-2-3-4 from passanger to driver's side?
Also have the intermitent front 02 code, but don't think it's related to the misfire.
Old Jun 16, 2009 | 01:06 PM
Update:
This makes no sense. Switch the coils today. Now misfire on cylinder 2!
1 and 4 are on one coil and 2 and 3 are on another (I'm assuming cylindes are numbered in a straight line).
So I shoul dhave expected the misfire on 1 or 4 after the swap, not on 2...
Any ideas?
CN: Misfire on 3, switched coils, misfire on 2....
Help!
Old Jun 16, 2009 | 02:03 PM
TIPSP's Avatar
Got Boost?
IF you switched the coils and it is no another cylinder missfire....Then it sounds like a bad coil.
Wait for the experts to get on....
Old Jun 16, 2009 | 06:17 PM
Normally, I would say yes. But there aren't 4 coils on the car. Only 2. One for 1 (cyl.) and 4 and one for 2 and 3. So, I took the 2/3 coil (after having a cyl 3 misfire) and swapped it with the 1/4 coil. That SHOULD result in a 1 or 4 misfire code, not a cylinder 2 code as I got. See what I'm saying?
The suspected bad coil didn't misfire on the cylinders I moved it to.
Can someone confirm that one coil is for cylinders 2 and 3, and the other for 4 and 1? Seems clear that's the case.
Old Jun 17, 2009 | 09:07 AM
Bump for any info/advice...
Old Jun 18, 2009 | 03:46 PM
TIPSP's Avatar
Got Boost?
Wait for Tech to get on....
or adub96....etc.
Old Jun 18, 2009 | 08:34 PM
Yes one coil is for 1 and 4 and the other for 2 and 3.
Not sure why it did what it did either very weird. But also alot of times both coils go at the same time. Or a wire is bad(Ignition wire)
notny41
Feb 28, 2007 08:58 PM
ko_kidd
Aug 25, 2006 08:53 PM
azmark
Jul 21, 2005 11:39 PM
robert
May 9, 2005 03:08 PM
procare
Mar 24, 2005 01:08 AM
