driver door will not unlock
Hello!
My key cannot unlock the driver side door anymore. I can still unlock the passenger side door and get in that way. However, it seems like the passenger side door is manual and the driver is automatic. Whenever I could unlock the driver side door, as soon as I started to turn my key it would trigger some sort of unlocking mechanism.
So I'm guessing a wire is broken in the electrical system in automatic locking of the driver side door. Is there a way to fix this without going to a mechanic? Or can I just reset the automatic locking device somehow to make it manual like the passenger side door? I know sometimes the gas cap door has to be reset and I'm not sure if there is something similar for the driver door.
Thanks so much!!
I have a 2000 volvo s40 if that helps.
Thanks so much!!
Hello!
Thanks so much!!
Thanks so much!!
I suspect that granted the unlocking motor is not broken, perhaps you can pull the door's interior panel away to reveal the mechanism and wiring, then you should check that everything is properly connected.
Does the lock budge at all or is it completely immobile when you turn the key?
I have the same car and I have a similar problem - the passenger's side door does not unlock all the way, so I have to manually pull the tab.
I haven't looked inside though so I can definitely try that. I just wouldn't be sure what I'd be looking at
stirderg3
12-28-2013 05:51 PM
adam0980
10-24-2008 11:16 AM
