DSA Warning light intermitant problem
Old Oct 6, 2009 | 08:50 PM
scoobysn7x's Avatar
Default DSA Warning light intermitant problem
Hi there I'm a new T4 owner (had it 2 weeks) and I'm loving it, but I am experiencing a problem with the DSA light, each time while I was driving the DSA light came on and stayed on, wouldn't go out when I pressed the button. The first time I was a 1 mile from work so I kept going, once at work I turned the engine off and started it again and the DSA light went out as usual. That night and it started fine and I drove about 5 miles then the DSA light came on again, again wouldn't go out when I pressed the button. At the next set of lights I turned the engine off and started it again, and the light went out and stayed out the rest of the way home. Its done this a few time will be fine one day then do it the next tyhen fine etc
Does this mean theres a fault with the system? if so does anyone no how I go about sorting it, and is it OK to use the car as normal??
Thanks in advance
nealeas
Mar 24, 2018 09:59 AM
john3-16
May 19, 2013 11:16 PM
mjcahill2009
Jun 24, 2010 01:15 AM
Genna
May 11, 2007 06:09 AM
gtsteve
Aug 4, 2005 12:38 AM
