reversing light intermitant
Old Aug 3, 2005 | 11:14 AM
gtsteve's Avatar
Default reversing light intermitant
On my '92 240 auto the reversing light has stopped. It was intermittant for a while working if the shifter was held a bit back and to the right. when I take the cover off the base of the shifter , what am I looking at next to fix it? Any ideas anyone?[sm=smiley25.gif]
Old Aug 3, 2005 | 04:07 PM
Ignavus's Avatar
Default RE: reversing light intermitant
The start inhibitor/back-up light switch is right under the cover, with the wires attached. Try loosening and sliding it forward about 1mm to see if that helps contact. If not, remove and replace ,or try accesing and bend the contacts. IF you remove, note location so it can be put pack in the same way, and only start in N and P.
Old Aug 3, 2005 | 09:42 PM
Look at it good I have seen them burned bad.
Old Aug 4, 2005 | 12:38 AM
gtsteve's Avatar
Thanks guys , yep that answers my question I should be right now.
rolling2
Sep 16, 2012 10:13 AM
rolling2
1998-2000 model year V70
Sep 4, 2012 11:06 AM
scoobysn7x
Oct 6, 2009 08:50 PM
johnbarnewell
Dec 21, 2007 02:11 PM
mavman
Aug 30, 2007 04:13 PM
