dynomax?
Old Jun 22, 2008 | 08:00 PM
shadowlord's Avatar
Default dynomax?
shop is making my 3inch downpipe and 2.5 inch rest of the system no cats, on a 05 T5 s40, the problem is i want my car as quiet as possible but not sacrificing to much performance.. i want to get dynomax turbo muffler and 2 resonators. Will this be a quiet exhaust or no and how much resonators help?
thanks
Old Jun 23, 2008 | 02:55 PM
mcguij1's Avatar
Default RE: dynomax?
make sure with your muffler that it is astraight flowing muffler..you dont want much restriction on the back end since its a turbo...
Old Jun 23, 2008 | 11:24 PM
shadowlord's Avatar
it si, it pretty much straight trough design , i just want my car as quiet as it can get with the least performance sacricified...
Old Jun 24, 2008 | 07:26 AM
mcguij1's Avatar
you should be fine since your keeping both your cats on there...
Old Jun 25, 2008 | 11:38 PM
shadowlord's Avatar
oh noo, he is putting straight pipe, no cats... i wonder whats gonna sound like....
Old Jun 26, 2008 | 09:31 AM
mcguij1's Avatar
its going to give you quite a bit more power, but you will def hear it since your taking your aftermarket muffler off too...make sure you'll meet your inspection as well with not having any cats onit..
Old Jun 27, 2008 | 09:30 AM
chimmychong's Avatar
taking out your 2nd cat and your first res. and throwing in a 2.5 stright pip...also replacing your flex pipe to a 2.5 in flex will give you 18+hp also around 10ish lbtrq.... dyno results say so .....
not much noise difference on this mod just a nice deeper sound when over 2500ish rpms...
not anything that noticable ..... also doesnt sound rice at all
and no CEL also can pass emmisions since all 02 sensors are on the first cat... but the first cat is the one with most rescrition of flow
Old Jun 27, 2008 | 10:20 AM
mcguij1's Avatar
he said hes taking both cats off...that definitely can affect inspections in some states.
Old Jun 27, 2008 | 12:50 PM
of yea it is itll throw a cel and the code is prob gonna be a p0420 cat below threshold......
You can buy these things off ebay to make your ecu think that there is a cat.
it makes the 2nd o2 sensor read a different reading from the 1st so the ecu thinks theres a cat and the 02 sensors are working just fine.... while actually you have no cats at all and your o2 sensors are just zipp tied on somewherezzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old Jun 27, 2008 | 12:54 PM
o never mind... i dont know if 05 s40s have 2 cats cause there totally different from the Ph1 and Ph2 s40s...I dont know if any of my statements are true because I over read the s40 being a 05 ... but you still can get a device that tricks the o2 sensors to think every thing is aok..... def. wont pass emmisions or smog or whater....
also you'll prob get fined if you get caught with that mod.... but thats a very very small chance and One i take with my 2nd cat and 1st res. out with a 2.5 stright pipe... Its the ****
Old Jun 30, 2008 | 09:48 PM
shadowlord's Avatar
ok. got thhe exhaust much better ecceleration but to deep inside the car especially toward the back seat
i still have to put the tips on, i used magnaflow straight through muffler and 36" cherry bomb at the end of the downpipe
what can i do to quiet the sound inside the car maybe some speaker sound insulationr text here. in the trunk or under the car...or tips should lead the exhaust little further out...any idea?
Old Jul 1, 2008 | 12:06 PM
mcguij1's Avatar
cherry bomb probably wasnt the best idea...not sure what you can do at this point...
Old Jul 1, 2008 | 01:10 PM
shadowlord's Avatar
yea i know cherry bomb is not good just kinda late now... i was wondering if it would be better if i bought a resonator from a muffler shop and installed it in the place of cherry bomb
Old Jul 2, 2008 | 07:33 AM
mcguij1's Avatar
perhaps, the cherry bombs are what the rice burners use...so its prob one of the louder parts..i would just look around..
