ECM 4D and P0303
Old Feb 5, 2009 | 06:57 PM
renejuan's Avatar
Default ECM 4D and P0303
Hi:
Where can I get the diagnostic trouble codes? What is the difference between an OBD aftermarket scanner and an specific Volvo diagnostic? For example, does the VIDA system will be able to detect more errors or more specific information than an aftermarket OBD?
I have a Volvo S40 that had the error P0303 and one of the mechanic changed sensors, spark plugs, ignition coil and clean the throttle body. After picking up the car the P0303 error came almost immediatelely. After a lot of troubles, I changed mechanic and they replaced the pressure regulator which solve the P0303 problem and a starting problem I was having. The first mechanic claim he solved the P0303 problem and the problem of the P0303 was caused by a the fuel pump. He showed me the diagnostic trouble codes. The DTC are the following:
ECM 4D: Is this the same as P0303?
ECM 44: What is this code?
After the second mechanic changed the pressure regulator the car is running great and no errors. Does the first mechanic failed to diagnose the problem or there were two problems? The spark plugs and ignition coils had about 24 k miles before he decided to replace it. Any opinions or comments?
Thanks,
RJS
Old Feb 5, 2009 | 09:03 PM
The P0303 is a cylinder 3 misfire. The first steps are to check/replace the spark plugs,coils,wires.
I cannot see the FPR fixing the P0303 code.
Old Feb 8, 2009 | 05:29 PM
renejuan's Avatar
I guess I did not ask the right question. The error ECM 4D have a description of cylinder misfire. It does not mention which cylinder. Is my P0303 the same as the ECM 4D? Thanks
Old Feb 8, 2009 | 08:14 PM
Usually that code will come along with a misfire code that leads to a cylinder. Sometimes it will come up first because it only sees a misfire but doesn't know which cylinder yet.
lrayvick
Aug 17, 2020 08:04 PM
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
dan42
Jan 7, 2009 02:46 PM
timothysoconnell
Sep 5, 2006 01:09 AM
