Erratic Temperature Gauge and Engine Fan
Old Aug 22, 2008 | 09:07 PM
Wufpack's Avatar
Default Erratic Temperature Gauge and Engine Fan
Hey to All! Just joined the forum here - looking forward to the discussions. Driving an 2004.5 S40 T5.
I searched the forums for coolant/temperature related posts and found lots of info on the coolant temp sensor/thermostat issues, but didn't see anyone mentioning strange gauge/engine fan behavior.
Under acceleration and sustained speeds, my temp gauge rises about 2 notches and stays there until I let off the gas and reduce speed, which brings the temp reading down. Seems strange to me since if there was an overheating potential, then I would think less airflow would make the temp rise not fall. At idle/sitting still, the reading looks normal.
Also, engine fan continues to run for several minutes after shutting down engine. This is a new occurrence for this car. Oh, and CEL has not come on either.
Could this also be a symptom of the coolant temp sensor/thermostat going bad? Have any of you experienced gauge/fan behavior? Could it be something with the turbo?
Thanks in advance for your help!
Old Aug 22, 2008 | 09:26 PM
Default RE: Erratic Temperature Gauge and Engine Fan
I would check that first.(Thermostat and sensor)
Old Aug 22, 2008 | 09:33 PM
Wufpack's Avatar
Thanks, Tech. I'll definitely do that first.
If it turns out to not be that, any idea what else it could be?
Old Aug 23, 2008 | 06:14 AM
Maybe something electrical maybe codes in the computer.
Old Jul 24, 2025 | 04:38 PM
Klodi's Avatar
Hi, I have the same problem with my 850 T5 MY 1996.
Have you fixed it?
How?
Thanks,
claude
Old Jul 28, 2025 | 10:40 AM
richardkonrad's Avatar
We have a spare car a Volvo s40 T5 2005 model that we purchased new , the fan always was on high after driving and then stopping but the temp gauge was always in the middle , but the temp gauge in the car is not accurate , connect a scan tool to the OBD and read the water temp while driving ,it does go up and down depending on engine load , which is normal from 90to 95 deg cel and to be fair some gauges will not move and others do , if the engine is working hard , like uphill etc the temp will always go up .the thermostat controls it but its not quick so one has always a small variant
But if it goes 2 notches up from middle when driving then its a problem and could be many things on a 20 year old car Faulty Gauge, bad radiator , worn water pump
When last was the water pump changed ?
Old Jul 28, 2025 | 11:58 AM
Klodi's Avatar
The water pump, all water circuit hoses, all turbo hoses were replaced while repacing the timing belt in September 2024, some 5700 miles ago. My temperature gauge goes DOWN while hard accelerating, not up.
Old Jul 29, 2025 | 11:04 AM
Ok so if it goes down ,on the temp gauge , is that at high speed with top gear , try same speed with lower gear if its ok then its the thermostat that is stuck open
Old Jul 29, 2025 | 11:34 AM
Klodi's Avatar
I had the thermostat replaced not long ago, but it was probably not an OEM Volvo. I’ll put the old thermostat back and also replace the temperature sensor by a new one…
Old Aug 1, 2025 | 10:01 AM
Before you do that connect a scan tool and select engine temp then go for a drive and see the actual temp read outs , these scan tools are not expensive now
Old Aug 8, 2025 | 12:31 PM
matdeinn3's Avatar
xJxwz
2001-2013 model year V70
May 16, 2023 07:08 AM
2000 volvo c70
Jun 1, 2020 04:52 PM
awfulwaffle
Oct 3, 2013 12:10 AM
blackbrick
May 7, 2011 01:46 PM
volvos701999
Feb 25, 2010 08:29 PM
