Exhaust leak? Flex pipe?
Old Feb 6, 2017 | 07:28 PM
travisvolvonj's Avatar
Default Exhaust leak? Flex pipe?
My 01 S40 has started to have a low end rumble ever since the temps have gotten cold. It can be heard at idle when first started, then can be heard when accelerating (around 1k-2k rpms) until the car is fully warmed up. Haven't had a chance to get it on the lift to inspect it, just wanted to see if others have had a problem around 90k miles. It feels like it is coming from where the flex pipe is located.
Old Feb 6, 2017 | 09:07 PM
yes its common for the flex pipe to fail on the Gen1 S40s. You can find replacement flex pipes to splice in ahead of the cat on Ebay for about $70 or you can opt to replace the whole cat with flexpipe for about $275 for the part (aftermarket Bosal - assuming you're not in CA). Note if you replace the cat, you will likely also want or need to replace the O2 sensors so that'll add another $200 for both.
Old Feb 8, 2017 | 05:54 AM
Hudini's Avatar
Also, if it starts sounding like a sewing machine until it warms up then check the bolts on the exhaust manifold. I had one bolt missing and a couple loosen up and it sounded funny until warm when the gaps would close up.
Laxbuddy48
Apr 1, 2007 06:31 PM
Laxbuddy48
Intake, Headers and Exhaust
Mar 30, 2007 04:35 AM
James1.9
Jan 17, 2007 08:51 PM
stejoymadandlaud
Sep 20, 2006 08:46 PM
shaman8888
Aug 22, 2006 02:49 PM
