fog lights 2003 S40
This connector piggy tails off my headlights, however it puts out only 5 volts
from multimeter I have read through several different posts here and most seem to say that they need to be programmed from the dealer. I am curious as why it only puts out 5 volts. Can one directly wire to cigarette lighter so they come on when ignition is on or would that be a no no? I figured it would be the same drl's https://cimg9.ibsrv.net/gimg/volvofo...19c7a0bb3b.jpg |
If you didn't have the fog light installed from factory then you will have to see the dealer to activate the lights.Ultimately yes you can hook the lights up to a different power source.
