Front door lock does not pop
Old Dec 24, 2010 | 01:55 PM
anisar's Avatar
Default Front door lock does not pop
My driver side front door lock does not pop open using the remote key. I can manually press it down to lock and open by using the interior lever for opening door.
Any suggestions will be appreciated
Old Dec 27, 2010 | 05:44 AM
southy's Avatar
I had this a while ago and the contacts needed cleaning inside the front door.
Old Dec 28, 2010 | 09:52 AM
AutoNaut's Avatar
Some of the S40/V50's had an issue with the door wire harness connector corroding when it got wet and produced the same symptom. You may need to find the connector, clean it and put a little dielectric grease around the connector housing.
Stan
Old Jul 3, 2017 | 08:02 AM
jwoertz's Avatar
Is dielectric grease really safe for the entire inside of the connectors?
Old Jul 5, 2017 | 10:01 PM
Hudini's Avatar
Dielectric grease only displaces water. It does not conduct electricity. It's safe inside any connector.
guest01
Apr 4, 2014 12:20 PM
rntaboy
Oct 14, 2011 09:15 PM
dennis5452
Jul 12, 2010 07:09 PM
yoyoman
Jul 12, 2009 08:57 AM
Dainos
Feb 11, 2008 05:33 PM
