Gas tank Door does not lock
Old Feb 9, 2008 | 10:02 PM
Dainos's Avatar
Default Gas tank Door does not lock
The door to my gas tank does not lock when the car is locked
Old Feb 9, 2008 | 10:23 PM
jmana's Avatar
Default RE: Gas tank Door does not lock
I didn't know they were supposed to?
Old Feb 9, 2008 | 10:31 PM
RedTurbo850's Avatar
Yeah, it's not supposed to.
Old Feb 9, 2008 | 10:59 PM
Dainos's Avatar
I'm sure that mine used to lock whenever I locked the car
Old Feb 9, 2008 | 11:03 PM
^It's a little door that you pull open....
The only way it would lock is if you had to pull a latch by your drivers side seat.
Do you have a lock mechanism on the back of your fuel door latch?
Old Feb 10, 2008 | 07:04 AM
The 850 gas door should lock when you lock the car.
It sounds like the motor is bad.
Old Feb 10, 2008 | 10:26 AM
^REALLY!?!?!
Old Feb 10, 2008 | 10:30 AM
Yes is should lock everytime you lock the car.
Old Feb 10, 2008 | 10:52 AM
Psaboic's Avatar
Yes, ours still locks every time you lock the car.....except in REALLY cold temps.
Old Feb 10, 2008 | 12:19 PM
quarterdimenickel's Avatar
It was an option to have a locking fuel door. Some of you have it, some don't.
Old Feb 10, 2008 | 12:34 PM
ORIGINAL: quarterdimenickel
That must be it.
After I read that, I took a trip outside into the FREEZING cold temperatures and took a look. My fuel door is just spring loaded. No lock.
Old Feb 10, 2008 | 01:44 PM
I'm sure that it's somewhere in the owner's manual. I read through the entire thing a few months ago and saw somewhere that some cars had the fuel door connected to the central locking system.
Old Feb 10, 2008 | 02:52 PM
Ozark Lee's Avatar
My gas door hasn't locked since I bought the car a couple of years ago. A couple of weeks ago it decided to lock but then not unlock. My wife usually drives the car and she was starting to panic as the gas gauge got lower and lower.
If you have a sedan and your gas door won't open just open the (US)passenger's side taillight door and look for a metal hoop along the side of the rear quarter panel. One pull toward the back of the car and you are filling up!
...Lee
Old Feb 10, 2008 | 05:40 PM
ORIGINAL: RedTurbo850
That must be it.
HMMM I have never seen one without the motor unless someone took it out of the car.
Old Feb 10, 2008 | 06:24 PM
Old Feb 10, 2008 | 08:36 PM
jmana's Avatar
Huh, learned something new about my cars! Both of them have locking fuel doors! All my old Mercedes had vacuum locking fuel doors, so I don't know why I never checked to see if my Volvo ones did the same.
Old Feb 10, 2008 | 09:22 PM
  #17
If that is your car the motor is there. Those 2 torx screws hold the motor in.
But your catch on the door itself that locks the door is missing.
Old Feb 10, 2008 | 09:29 PM
  #18
^Interesting........
I would have never thought that in '95 Volvo had anti-siphoning measures.
Edit: But if you take a look at my door itself, it doesn't look like it has anything for the door to lock into. The wear on the door doesn't look like it matches up with the lock...
Old Feb 11, 2008 | 05:33 PM
  #19
A bracket is supposed to come off the door and go into the hole.
Like this.
anisar
Jul 5, 2017 10:01 PM
rntaboy
Oct 14, 2011 09:15 PM
dennis5452
Jul 12, 2010 07:09 PM
guptash
Nov 25, 2008 09:39 PM
AzNick
Oct 30, 2008 03:50 PM
