Front End Vibration
Old Dec 9, 2013 | 07:15 PM
elandthaler's Avatar
Default Front End Vibration
My daughter has a 2001 Volvo s40 loves the car , I drove it the other day and noticed a vibration in the drivers side front end when acceleration on up hills . It easies up if you get the accelerator, I did check the lower transmission mount and it looks /feels good . any help ??
Old Dec 13, 2013 | 08:40 PM
Check the control arm or have a shop check it.
Old Dec 15, 2013 | 02:30 AM
Hudini's Avatar
The are 4 mounts total. On my 2001 worn out mounts caused a shake while idling in gear with your foot on the brake.
Does it make any clunking noises?
Old Dec 17, 2013 | 12:25 AM
volvo_newbie01's Avatar
Upper strut mount, ball joint, sway bar link or cv shaft.
Old Dec 17, 2013 | 08:53 AM
austinnoah1's Avatar
I just went through this on my 2000 Volvo S40.
It doesn't do it when idling or when the engine is NOT under load right?
If so... Go under the front driver side to the Inner CV Joint and give it some movement (i didn't want to use the word shake but that's technically what you're doing).
If it has any play in it, then you might as well replace the Entire Axel on that side.
The Axel is about $160.00 for a Dura-last with a lifetime warranty. And to replace it yourself will take about an hour.
It's not hard to take out. It's just like any other standard car. You need a Half Inch Socket to take off the Axel Nut. I would suggest a Craftsman wrench. The reason being for the craftsman wrench is because when we were trying to pull mine off, of course it had been put on by a Torque Wrench. So we bent 2 and completely broke 1 of the 1/2" sockets. (craftsman's have lifetime warranties no matter how many you break they will hand you a new one)
Just take precaution. It's really not that hard to get that thing off and back on.
Now if you aren't to DIY, then taking it to a volvo mechanic is your best bet. It's probably going to cost you a pretty penny to get "certified volvo" tech on it.
Old Dec 18, 2013 | 08:35 PM
the car has a auto trans I forgot to mention that, there is no clunking noises just a vibration that I can feel when pulling a hill . If you let off the accelerator it goes away, no vibration in the steering wheel. Help ?? Thank you guys for the input
Old Dec 20, 2013 | 06:04 AM
Hudini's Avatar
I think austinnoah1 answered quite nice. He suggests a test to confirm.
RPMCanes
Sep 10, 2016 09:58 AM
casualfc
Oct 6, 2008 09:34 AM
ocean238
Apr 17, 2008 06:20 PM
DaveNY
Aug 2, 2005 10:03 PM
JimKW
Jun 14, 2005 06:38 PM
