vibration, vibration, then more vibration
Old Apr 16, 2008 | 04:48 PM
ocean238's Avatar
Default vibration, vibration, then more vibration
Hi guys
I have had this problem for a very long time now, tried pretty much everything:
basically all started i can't really remember when:
first : up to 85mph then vibration starts stops over 90mph
- thought it was a slow puntcher, which then the tyreswere replace all around
then gone for a while, and came back
had tracking done because i thought it was that, then the garage messed up my tracking, and the vibration was still there
then had tracking checked again and the garage said i have to replace my front wishbones, so i did
vibration is reduced but still there and i do notice it and now at around 70-80 mph it vibrates
then I thought it was to do with a leaky wheel at the front and hence unbalanced tyre pressure, had that fixed, no change
then had all wheels balanced again and tracking redone today, and now it vibrated at 60-70mph, worse than before.
vibrations is only through streering wheel.
I have had all brake pads replaced cos I once thought it was the brakes.
i have tried different tyre pressure, and not really changed anything, but higher pressure will results is less feeling of vibration, but still there at the particular speeds
what do i do now???? Thanks!
Old Apr 16, 2008 | 07:55 PM
Default RE: vibration, vibration, then more vibration
Is the tires out of round?
Old Apr 17, 2008 | 05:43 AM
ocean238's Avatar
actually coming to think of it, I remember swaping the backs with the fronts and the vibration was gone (i think, don't remember clearly)
the tyres are all quite new, altho i haven;t checked to see if they are round
Old Apr 17, 2008 | 06:20 PM
Sometimes the belts will shift in the tire causing a vibration. Even on new tires it does it.
karan5nabha
Apr 21, 2014 08:35 AM
Dennis Bor
May 30, 2011 11:14 AM
mstrplmber
Jun 26, 2010 04:10 PM
gordon368
Jun 6, 2009 03:01 AM
