front rotors
Old Feb 12, 2008 | 09:07 AM
zerochills's Avatar
Default front rotors
anything special to know about when replacing front rotors? What size/head are screws holding rotor to hub?
Thanks
Old Feb 12, 2008 | 10:09 AM
jks2's Avatar
Default RE: front rotors
You should stay with OEM or better (Brembo, etc.) I would be leery of off brands. The quality might not be there and warpage, increased stopping distance, etc. could come into play. Whatever you do, don't have the rotors turned. Volvo does not recommend turning rotors as they can warp. Can't help with the screw question.
Old Feb 13, 2008 | 02:28 AM
drinkduff77's Avatar
I did front rotors and pads about 5k ago and used Brembo rotors from fcpgroton.com. Very straight forward and no surprises during the job. First time I've ever done rotors too. Rotors are held to the hub just by the wheel studs. Take the brake caliper off and the rotor just pops off. You might need to tap it with a rubber mallet or block of wood. Brake caliper bolts are on TIGHT. Turn the wheel and use a cheater bar.
Old Feb 16, 2008 | 07:53 PM
Hudini's Avatar
I used Brembo too. Very satisfied. As said above, they are held only by the pressure between the wheel and hub and the studs keep it aligned. The calipers should be torqued correctly as well as the wheel studs when you stick it all together.
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
mrvolvos60
Sep 11, 2014 07:39 PM
eldee50
Sep 18, 2007 08:21 AM
mahie023
Nov 10, 2005 10:03 PM
