gear selector lockup
Old May 10, 2011 | 02:20 PM
micsav1938's Avatar
Default gear selector lockup
I took the starter off a 2001 vovlo s40 put it back on and now the car will not even attempt to start and the gear selector will not move out of park(or anywhere for that mattter)
Old May 10, 2011 | 10:27 PM
ShowTek's Avatar
Immobilized? have you already used the overide button?
Old May 11, 2011 | 03:20 AM
micsav1938's Avatar
What and where is the overide button?
Old May 11, 2011 | 07:34 AM
Choguy03's Avatar
Yeah, your security light will flash I believe if it thinks you are try to start the car 'illegally'. Check to see if that is happening. Did you unlock the car with your fob? If you tried starting it without doing that the car still thinks the doors are locked. I also know that there is a period of wait time after the immobilized light comes on. Maybe 5 or 10 minutes.
Old May 12, 2011 | 11:56 AM
micsav1938's Avatar
No good. It's still stuck.Anybody got any other suggestions?
Old May 12, 2011 | 12:26 PM
Choguy03's Avatar
There is a lock button right above the gear shifter. Make sure that is not stuck in, that can cause your problem too.
dongriffin
Aug 24, 2008 05:03 PM
Spencercb22
Mar 27, 2008 06:58 PM
volvogltturbo
Dec 26, 2007 11:44 PM
paulbelanger
Aug 9, 2006 10:13 PM
