Headlamp Not Working
My wife has a 2001 S40 and she came home last night with the front driver's side headlamp out. I bought a set of bulbs and installed them and the lamp still didn't work. I tested it with a meter and got nothing. I noticed that there were left and right low-beam fuses, so I checked the fuse. The fuse was good. I was doing some experimenting with my tester and came across something very unusual.....I pulled the left lamp fuse out and tested the circuit - .8 volts. I then pulled the fuse for the right lamp and tested it - 14+ volts. With both fuses out, I tested the left lamp circuit again and it then read 14+ volts. The left lamp circuit appears to drop voltage when the right lamp fuse is in place. Any suggestions????
Also...Why is this ad at the top of the Volvo Forums page??
Enclave vs. Volvo XC90
See How the Buick Enclave Stacks Up Against the Volvo XC90.
www. GM. com/ BuickEnclaveWins
Sunshine2007
09-26-2012 02:14 PM
