-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   headlight problem (https://volvoforums.com/forum/volvo-s40-11/headlight-problem-5687/)
jojoswhip May 7, 2006 09:53 PM
headlight problem
I just recently changed out my headlights to the ones with the black bezel for my 2002 s40 1.9t. I have a problem with the passenger side one. It doesnt seem to be fully lit. both the high beam and low beam seem to be on but dim. the left one only has the low beam on. when I turn the high beams on, my left one lights up as it should and the passenger side turns completely off for low and high beam? Am I missing something? I checked the connections and everything seems fine. help??!!!!
tech May 8, 2006 01:37 AM
RE: headlight problem
Sounds like a Bad ground.
jojoswhip May 8, 2006 01:59 AM
how can I fix the ground or check tosee if thats what it is?
tech May 8, 2006 08:41 PM
Usually the ground is screwed somewhere close to the lights.
You might also want to try checking a wiring diagram and make sure none of the wires for the new light are different from the old one.
