headlights and moisture
Old Jun 23, 2006 | 02:11 AM
jojoswhip's Avatar
Default headlights and moisture
recently my headlights have accumalated moisture in the glass? what is that happening from and is their anthing I can do?
Also what can I do to adjust how far the light beams out. I know their is an adjuster that is supposed to have a **** on it and mine doesnt have the ****? what do I need to do to even the lights.
Thanks.
Old Jun 26, 2006 | 10:00 PM
Default RE: headlights and moisture
What year is the car?
Old Jun 27, 2006 | 03:38 AM
jojoswhip's Avatar
the car is 2002 s40.
Thanks
Old Jun 27, 2006 | 08:23 PM
I assume you have no Warranty left?
You might need to remove the Light assembly and take the light apart to dry it out.
Then make sure it is sealed good.
Moisture= Air leak.
To adjust you should have a spot on the back to use a Phillips Screw driver to adjust.
Old Apr 19, 2009 | 06:21 PM
Jimbo_Jones's Avatar
I have the same problem. There is moisture / condensation in one of the 2 headlights. I recently had removed the plastic cap to try to replace a bulb.
Does anyone have a good idea as to how to fix this problem. Maybe remove the cap and let it air out, making sure that it is a nice and hot, dry day (and obviously not drive the car with the cap removed)? I assume the problem was that I didn't replace the cap properly, but maybe it was something else.
Thanks
Old Apr 19, 2009 | 07:34 PM
djalmab's Avatar
Default Not really your fault..
Mine also have some "fog" on both headlights when the day is humid..
Tech,
i don't get when you tell that's because of air as these headlights are not "sealed beam" shouldn't they let air in anyway ? Can you please ellaborate on that ? I would expect that some air would be trapped and those headlights would have some air flow ( even mininmal) inside them..
Regards,
Old Apr 24, 2009 | 02:35 AM
conn's Avatar
Moisture accumulates in the headlights if you take your car often at a car wash. It is much more wiser to wash your car on your own.
Cracker39
Apr 23, 2014 12:13 PM
VDriver24093
Feb 21, 2011 04:35 PM
jmc_gtr
Feb 26, 2007 12:33 AM
casique
Feb 13, 2007 07:47 AM
indiana
Mar 12, 2006 02:13 PM
