Help: Oil leak of unknown origin!
Hi,
ive got a 2003 v40 with 200k miles that has developed an oil leak in The vicinity of the oil pan/transmission area. Or rather that is where I’m seeing all the oil accumulate. At this point it’s about 1 quart for every 3000 miles but it looks to be getting worse. I’ve attached a bunch of pics. Feel free to weigh in with any guesses. Back of engine (turbo side) is clean.
Here is is a link to a Dropbox folder with some pics.
https://www.dropbox.com/sh/nbdjdcp82...CpEMoA7Ca?dl=0
Any opinions are welcome.
I'm pretty sure it's going to be a rear main seal leak. The bad news is that you're going to have to pull the transmission to get to it. With 200,000 miles (and a fair bit of rusty hardware underneath) you may find that's not an economical option. There are products that claim to rejuvenate worn seals, though I would be skeptical, but it might well be worth spending a few bucks to try one (acknowledging that it might not be the best thing for the engine in general). Another option is to stuff a shop towel into the gap between the transmission and oil pan, and change it when it gets soaked. Oh, and check your oil regularly. ;-)
Thank you Habby, Yeah I’m inclined to think the same thing regretfully. I’m going to try replacing the seal on the oil pan just in case it turns out to be something easier. But I’m not optimistic.
I wouldn't bother with the pan gasket - oil leaks pretty much always travel down, not up, so you can trace the path pretty easily. On many leaks, it's a good idea to clean up the entire area with engine cleaner / degreaser, and then the leak path will be pretty evident.
If you do end up deciding to try a leak stop product, you might do what I do and use the considerable number of reviews on the amazon shopping site to see how various products have worked for others. Naturally, many of the reviews will be bogus (either to boost a product or denigrate it) but it's pretty easy to spot the real DIY'er reviews, and to get a feel for how likely it is that the stuff might actually do something positive.
Here's a link to a quick search I just did...
Well I removed the oil pan and resealed it. Interestingly there was ZERO liquid gasket on the mating surfaces. Is this common? Does the Volvo factory just slammed these two pieces together without any sealant? There was a fair amount of oil on the mating surface of the pan closest to the tranny. I’m hopeful that the seal on the pan just gave out. Very strange thought that there was no trace of any gasket whatsoever.
Wow - that's hard to imagine. You can build something like that without gaskets if you have a NASA-style budget and engineering, but there's no way the pan should rely on metal-to-metal contact to prevent oil leaks. It looks like the right product is a silicon sealant (based on a quick search for an S40 oil pan "gasket"). I really hope this fixes your (big) leak! I had mistakenly thought that the leak was starting above the pan, but I can see now that it isn't, so I'm thinking you're very likely to fix your leak with some sealant. Surface prep is everything when using silicon to seal an oil pan so take your time and really get the surfaces shiny and clean before applying the goop.
Thank you habby. I'm hoping this does it. I did my best to clean everything up before re-assembling. One thing is nagging at me though. There was a very small amount of oil dripping down the inside of the back of the pan which I kept wiping off in prep for re-installation. Thing is, I forgot to give it one was wipe before final assembly and I'm worried that I pressed the two pieces back together with some oil residue present in between. Luckily I used the super expensive Volvo liquid gasket so I'm hoping that whatever magic they pack in there to justify the stupidly expensive cost will be able to cope with a bit of oil...we'll see.
well, re-sealing the oil pan didn't do jack s&&t. Leak is back, oh and now the oil cooler is leaking because the overpriced gasket kit for the oil pan of course doesn't include two new seals for the cooler. Love it.
__________________
__________________
I'd suggest fixing the seals for the cooler, and then cleaning the entire area. The leak may be coming from somewhere you aren't expecting, and I'd hate to see you spend a whole lot of time trying to fix something that ends up not being a problem...
My method is a bit simpler. With the engine fully warmed up, pull the dipstick up a bit while idling. If you see a stream of gasses coming out the dipstick, the PCV system is plugged.
However, if you remove the cap with it running and you hear a pressure release, you've confirmed what I'm testing for.
So here is an interesting twist. Started the car up today and thought, something is different t on my instrument cluster...the CEL light turned off for the first time in 2 years! It was a P0015 code that I had previously racked my brain about. Now whether this is a total coincidence I’m not sure but maybe replacing the two oil pan seals got my oil pressure back up? Beats me. Very timely though as I was soon going to set a day aside to do the vvt again. Let’s hope it stays off now.
