Help tech! 2001 S40 starts intermittantly
Old Dec 8, 2005 | 11:32 PM
Hoopicide's Avatar
Default Help tech! 2001 S40 starts intermittantly
I have a 2001 S40 75,000 miles, and it won't start intermittantly. When the key is turned in the full start position
the fuel pump turns on and all other electrical stuff is working, but the engine won't turn over.
We took it to a Volvo dealer and after $$$ they couldn't find the problem.
I have seen on one forum that someone had to have their ignition cylinder lock replaced for a similar problem.
This problem seems to happen on cold days and after the car has run for a while. It used to only happen once in
a while, now it happens almost every day.
Tech, or anyone else, what do you think? I am tired of getting stranded....
Thanks for your help,
Hoopicide
Old Dec 9, 2005 | 12:23 AM
Default RE: Help tech! 2001 S40 starts intermittantly
I think I would look at the starter first. Wire a light bulb inline that you can watch. And when it acts up if the light bulb lights and it won't crank the starter is bad.
Ghost Brick
Apr 1, 2010 03:48 AM
bammers
May 8, 2009 06:27 PM
onthepond
Dec 28, 2006 11:13 AM
onthepond
Hoopicide
Jan 2, 2006 09:18 PM
