How to Disassemble the Center Console on a Volvo S40/V40?
Old Dec 3, 2007 | 03:02 PM
zolee1's Avatar
Default How to Disassemble the Center Console on a Volvo S40/V40?
Hello All!
I have a 2001 Volvo S40. The cigarette lighter (12V Power Outlet) broke on my center console. It just dropped into the whole where it was sitting on. I might have pushed it too hard.
I managed to pull it back, but something broke off and if I push it a little harder it will go back again. I would like to fix it somehow permanently, but I couldn't take apart the center console.
A step by step instruction would be really helpful. Thanks in advance!
Old Dec 6, 2007 | 12:40 PM
billofdurham's Avatar
Default RE: How to Disassemble the Center Console on a Volvo S40/V40?
Hope these help:
[IMG]local://upfiles/4491/6708B732DEBE449199BC2890C1D2C23D.jpg[/IMG]
[IMG]local://upfiles/4491/195A2A29D2184EC8A5FD609B2A5FD486.jpg[/IMG]
Old Dec 6, 2007 | 01:43 PM
zolee1's Avatar
Thanks very much billofdurham!
Not sure if you can help, but I had a problem with locating the rear cetner console guard (3). I have rigid insert in there and I am guessing the guard is underneath, but I couldn't get this insert out.
Thanks again!
Old Dec 6, 2007 | 04:49 PM
On other Volvos the 'guard' is an insert that hides the screws and can be prised out using a fine screwdriver or a thin blade. I am not sure about the S/V40 but would have thought the same would apply.
Old Dec 6, 2007 | 05:07 PM
zolee1's Avatar
Thanks very much. That seems to be the case with mine S40. I will keep tring.
Thank you again for your help!!
Old Dec 21, 2007 | 01:22 PM
shaggy1's Avatar
anything like this for taking the radio out? or does it come out easily after i take the console piece off? thanks!
Old Dec 21, 2007 | 04:44 PM
Take the radio out by pushing in on the two catcheson the face of the head unit. They will pop out when you remove your finger. Take hold of them and pull them out as far as they will go and the radio panel will slide out of its housing. Make sure you have the radio code if you are going to disconnect the unit.
Old Feb 4, 2008 | 06:49 PM
shaggy1's Avatar
thanks! i was all set to install my FM modulator for my Zune until i found this lame proprietary antenna connector :/
Old Oct 5, 2009 | 03:56 PM
mattg's Avatar
Hello, I have the same problem with the cigarette lighter having fallen down into the centre console. Unfortuntely I can't see the pics that billofdurham provided, so would be grateful if someone could provide them again or some instructions. Thanks very much in advance.
rudsaki
Aug 5, 2015 04:15 PM
PHIL_V70_GLT
1998-2000 model year V70
Aug 30, 2012 11:04 PM
shelby187
Jan 8, 2012 03:59 AM
Boxman
Apr 17, 2011 06:21 AM
gesmarty
Mar 17, 2011 12:33 PM
