Inputting Radio Code on Volvo s40 2002
Old Jun 8, 2017 | 01:07 PM
Newport_j's Avatar
Default Inputting Radio Code on Volvo s40 2002
I just got my 2002 Volvo s40 back from repair shop. I cannot turn on the radio because I must input a code. I know the code. I just do not know how to put it in.
Any help appreciated. thanks in advance.
Respectfully,
Newport_j
Old Jun 8, 2017 | 02:18 PM
Smith Volvo's Avatar
Banned
Respectfully,
Newport_j
simple - when it says 'code', enter the number using the pre-set buttons
if it says 'off' - you must wait 2 or 3 hours with the power on before it goes back to saying 'code'
Old Jun 8, 2017 | 02:34 PM
ES6T's Avatar
Yours will have a preset ****, but the rest applies. See your owner's manual for details.
Old Jun 11, 2017 | 08:57 AM
Corey Conklin's Avatar
Use the middle **** to adjust the numbers, once you find the number you need press the **** then it should bring you to the next.
Old Nov 23, 2020 | 07:09 PM
98Unicorn's Avatar
Bought a 1998 V70 in 2018 in Cali. Replaced the battery tonight and went looking for the radio code. Found it...along with the card showing it was sold at Smith Volvo:0. It now lives in Pa. Now I need to find out how to get that battery light off...
Old Nov 24, 2020 | 04:36 AM
Hudini's Avatar
The alternator light? Is it charging?
Old Nov 24, 2020 | 02:06 PM
put a volt meter across the battery terminals - should be 12.6 or so for a charged battery. when you start the car, it should be between 13.5 and 14.5 depending on load (ie lights etc). if it says around 12 with the engine running, you need a new alternator or voltage regulator.
Old Nov 24, 2020 | 07:18 PM
98Unicorn's Avatar
I disconnected it and made sure the terminals were clean today. Reconnected and light has disappeared. I got a voltmeter today and checked it. Charge is fine, maybe a little low but within specs. I'm going to keep checking it every few days. Thanks for your help!
Old Nov 24, 2020 | 07:22 PM
98Unicorn's Avatar
I had to go get a voltmeter. Old ladies don't usually have them laying around I guess. Apparently I don't know how to reply on threads either as I've never done so. Guess I'll figure it out like I do with most things in life anyway, the charge is good. A bit on the low side but within specs. Thanks for your advice
darrenthehippo
Sep 8, 2011 06:17 PM
Stanl
Jun 15, 2010 09:49 PM
xxgolfpro
Nov 8, 2008 09:18 AM
ctphil
Dec 18, 2007 07:54 AM
